May 26, 2026 10:50 AM UTC
data roaming not working
My data wont work. I followed all self help tips. Still not working
    Owethu M
    May 26, 2026 11:51 AM UTC
    Hi ​@Dorinaxi,
    We’re sorry to hear that your data roaming is still not working despite following the self-help troubleshooting steps.
    Please ensure that roaming is enabled both on your iD Mobile account and within the handset settings.
    To check roaming and Bill Cap on the iD Mobile app:
    • Log into the iD Mobile app
    • Go to “My Services”
    • Select “Roaming”
    • Ensure Roaming is enabled
    • Go to “Bill Cap”
    • Set the Bill Cap to £0 to help avoid unexpected out-of-plan charges whilst abroad
    To enable roaming on your handset:
    iPhone:
    • Settings
    • Mobile Data
    • Mobile Data Options
    • Turn “Data Roaming” ON
    Android:
    • Settings
    • Connections / Mobile Networks
    We would also recommend:
    • Restarting the handset
    • Turning Airplane Mode ON for 60 seconds, then OFF again
    • Manually selecting a network provider:
      • Settings
      • Mobile Networks
      • Network Operators
      • Turn automatic selection OFF
      • Try connecting to one of the supported partner networks manually
    Please also ensure you are connected to a supported roaming partner network in the country you are visiting.
    You can also check the included roaming destinations and supported networks here:
    iD Mobile Roaming Destinations Guide
    Owethu
    DorinaxiAuthor
    May 26, 2026 12:11 PM UTC
    Still not working. I am really disappointed. What else can I do?
    Owethu M
    May 26, 2026 1:02 PM UTC
    Hi ​@Dorinaxi,
    I do apologise that steps provided did not assist. Please contact us Live Chat or our social media platforms so that we can have a look into the account.
    Owethu
