Data roaming not working in Europe
I have recently returned from travelling in Austria and Hungary and was unable to use data at any time. My phone settings were set to roaming. I was regularly showing 5 bars of 5g reception with R being displayed. I tried switching from airplane mode and back, changed service providers, rebooted the phone several times, but nothing worked. I had to rely on WiFi the whole time. Now I'm back in the UK everything is working normally. Does anyone have any ideas?
Michael.
    paul0363Answer
    Is data roaming enabled on your account here:
    https://my.idmobile.co.uk/plan/manage-id-services ?
    It’s under Plan>Manage Your iD Services if the link doesn’t work
    Lamiya C
    Hi ​@MCallaghan ,
    Thanks for reaching out, and I’m really sorry you couldn’t use data while abroad. Since your settings were correct, here are a few things that might help:
    -Make sure Data Roaming is switched on.
    -Check that your APN settings match iD Mobile’s (you can find these in the iD Mobile app or website).
    -Ensure your plan includes EU roaming and you haven’t hit any usage limits.
    -Try manually selecting a different network again while abroad.
    Since everything is working now that you're back in the UK, it may have been a temporary network issue. If it happens again or you'd like us to check further, please contact us via Facebook, Instagram, Live Chat, our Community, or email socialqueries@idmobile.co.uk.
    Lamiya
    iD Mobile Social Media Team
    Thanks for the reply, but I did all the things you suggested. I was away for 12 days so a network problem seems unlikely.
    paul0363Answer
    Thanks. That looks like the problem. The box for roaming on my account was unticked. No idea how it got unticked as I used the phone abroad last year and had no problems. Thanks for the help. I’ll be checking that the roaming box is ticked the next time I go abroad.
