May 27, 2026 2:28 PM UTC
data roaming not working in turkey after payment
Why is my data roaming for turkey not working - I paid for it 2 days ago and it is still not working.
    Owethu M
    May 28, 2026 10:25 AM UTC
    Hi ​@Timmyanne,
    We’re sorry to hear that your Turkey roaming add-on is still not working, especially after purchasing it 2 days ago.
    Please try the following checks and troubleshooting steps:
    Ensure your Bill Cap is set appropriately
    On the iD Mobile app:
    • Log into the app
    • Go to “My Services”
    • Select “Bill Cap”
    • Set the Bill Cap to £0 or a suitable amount
    Ensure Roaming is active on your account
    • Select “Roaming”
    • Ensure roaming is switched ON
    Ensure Data Roaming is enabled on the handset
    For iPhone:
    • Settings
    • Mobile Data
    • Mobile Data Options
    • Turn Data Roaming ON
    For Android:
    • Settings
    • Connections / Mobile Networks
    Manually connect to a supported partner network in Turkey
    Please manually connect to:
    • AVEA
    or
    • Turkcell
    To manually select a network:
    iPhone:
    • Settings
    • Mobile Data
    • Network Selection
    • Turn Automatic OFF
    • Select AVEA or Turkcell
    Android:
    • Settings
    • Connections
    • Mobile Networks
    • Network Operators
    • Turn Select Automatically OFF
    Please also:
    • Restart the handset
    • Turn Airplane Mode ON for 60 seconds, then OFF again
    • Try setting the handset to 4G/LTE only
    If the issue still continues after trying the above, please contact our Live Chat Team so that an agent can investigate the roaming services further for you.
    Owethu
