Data Roaming not working in Washington D.C
  • September 7, 2025
  • 207 views
im currently in Washington D.C and my roaming isnt working, ive purchased additinal data but still i cant get any roaming, it says my allowance is 207G which is more than my 110G, meaning that its added the extra data charges, but still isnt working, can anyone help?
    Best answer by WelshPaul
    The USA isn’t included as a roaming destination, so you won’t get to use any of your plans included allowances while travelling there. You need to purchase a Roam Beyond add-on.
    Roam Beyond add-ons.
    You can now buy a data-only add-on to stay connected while you're in United States (USA). Use your data to browse, stream, and keep in touch with friends and family at all times. To get an add-on, simply log in to the iD Mobile app or my.idmobile.co.uk.
    Data Duration Price
    2 GB 1 day £5
    10 GB 5 days £20
    20 GB 10 days £35
    Tip: To avoid out-of-plan charges when you land, it's best to purchase your Roam Beyond add-on while you're still in the UK. Alternatively, once you reach your destination, keep mobile data turned off until you can connect to Wi-Fi and buy an add-on.
    WelshPaulAnswer
    Data Duration Price
    2 GB 1 day £5
    10 GB 5 days £20
    20 GB 10 days £35
    Siân W
    Hi ​@Jackwsimms  I hope the reply from ​@WelshPaul  has helped and you were able to get the roam beyond add on.
    Have a fab trip!
