Trying to add data roaming for Turkey last couple of days but error message states can’t add and try later. I fly today 🙈 anyone else had this? I’ve tried the network reset and check my phone and plan is set for data roaming. ID can’t help as they say they’ve issues 🙄🙈 Thanks
Data roaming wont add on to my account
Okay
Just Google “travel eSIM for Turkey” to see some options.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
Log in with FacebookPlease note: From 31st July 2025, you'll no longer be able to Log in with Facebook. To keep using the iD Community, you'll need to create a password. Click 'Forgot Password?' to get started.
or
