Aug 12, 2026 10:01 AM UTC
data roaming wont work Montenegro
I have an iPhone 17 pro max, travelled to Croatia and my phone worked as usual as roaming was included, roaming is switched on on the phone and on idmobile app. I bought an add on for Montenegro however it does not work, I cannot use data to search for anything online
    Tashnieka D
    Aug 15, 2026 2:32 PM UTC
    Hi ​@JESSCRAMOYSAN,
    I am sorry you are having trouble getting your mobile data working in Montenegro, especially as your phone worked normally in Croatia and you have already purchased the relevant roaming add-on.
    As roaming is switched on both on your iPhone and your iD Mobile account, please try the following:
    • Go to Settings → Mobile Data → Network Selection and turn Automatic off.
    • Your iPhone should show the available local networks. Try selecting a different network and then test your mobile data.
    • If that does not work, try another available local network.
    • Turn Airplane Mode on for around 60 seconds, then switch it off.
    • Restart your iPhone and test your mobile data again.
    If you are still unable to use data after trying the available local networks, please contact our Live Chat team so they can check your account and roaming settings further.
    Live Chat: https://www.idmobile.co.uk/live-chat
    Tashnieka
    The iD Mobile Team
    Tashnieka D
    Hi ​@JESSCRAMOYSAN,
    Tashnieka
    The iD Mobile Team
