Jan 27, 2025 11:28 AM UTC
does phone ring when roamjng is rurned ofd?
Hi, my mum went on holiday to Tunisia
She says she turned roaming off.
However, when she got the bill, she has been charged for receiving calls from her nephew.
So, what does turning roaming off actually do?
If roaming is turned of, will your phone ring?
will you get SMS messages.
Cheers in advance, Paul.
    Kash MAnswer
    Jan 29, 2025 2:04 PM UTC
    Hi ​@Pattayapaul,
    When roaming is enabled it allows data access in a region outside of the UK.
    If you wish to stop receiving all services I would advise to enable Airplane mode or remove the SIM.
    You would only be charged if the phone was answered.
    The roaming charges for Tunisia are outlined below:
    Roaming Pay monthly Pay-as-you-go****
    Calls to UK* £6.00 £6.00
    Calls to Tunisia* £6.00 £6.00
    Calls received* £1.50 £1.50
    Texts to Tunisia** £1.20 £1.20
    Texts to UK** £1.20 £1.20
    Picture message (MMS) sent** £0.60 £0.60
    Internet and Data (per MB)*** £9.60 £9.60
    Kash MAnswer
    Hi ​@Pattayapaul,
    Dec 16, 2025 12:27 PM UTC
    What about using Google messages to receive messages. Will they cost outside the free roaming area?
    Dec 16, 2025 12:34 PM UTC
    Hi ​@edwhow01
    Just to let you know, any services used outside of iD Mobile’s roaming destinations will be chargeable.
