Apr 11, 2026 7:16 AM UTC
excessive roaming charge
I’m new to ID mobile. I recently travelled to Australia and stopped over in Singapore. I switched off flight mode in Singapore for 10 minutes, made no calls and have been charged £40 across 2 sims. How can that happen?
    Zandile M
    Zandile MAnswer
    Apr 11, 2026 9:49 AM UTC
    Hi ​@Submariner
    Thank you for getting in touch, and we’re sorry to hear about the unexpected charges.
    We understand how concerning this must be, especially as you were only in Singapore briefly and did not intentionally use any services.
    When a phone has roaming switched on (or briefly enabled), it can still connect to a local network automatically, even without making calls or sending messages. In some cases, background data such as app refresh, email syncing, system updates, or network registration can occur as soon as the device connects. These small data sessions can trigger roaming charges, even within a short period like 10 minutes.
    As you are using two SIMs, it’s also possible that both devices or both lines registered on the local network during your stopover, which would explain why charges have appeared on each SIM.
    We appreciate this is frustrating, and we’d like to look into this for you in more detail. Please send us a private message so that we can look into this issue for you.
    Zandile M
    The iD Mobile Team
    Zandile M
    Zandile MAnswer
    Hi ​@Submariner
    Zandile M
    The iD Mobile Team
    Apr 11, 2026 11:08 AM UTC
    Thanks Zandile. Not sure how to send a private message? Please advise.
    Apr 13, 2026 2:06 PM UTC
    Hi ​@Submariner ,
    I'll speak to you there.
    Michael Z
