Aug 19, 2026 7:23 PM UTC
help
Lost mobile serviceĀ
    Zandile M
    Aug 20, 2026 11:22 AM UTC
    Hi ​@Alfie2402Ā
    Ā
    Thank you for your review. We are sorry to hear that you have lost mobile service and understand how inconvenient this can be.
    Ā
    In the meantime, you can check the coverage in your area using the link below:
    You may also find it helpful to try the following steps:
    Reinsert your SIM card
    Try your SIM in another phone
    This will help determine whether the issue is related to your handset or the SIM card.
    For iPhone (iOS) – Reset Network Settings:
    Go to Settings → General.
    Tap Transfer or Reset iPhone → Reset → Reset Network Settings.
    Confirm the reset when prompted.
    Once complete, return to the home screen and restart your iPhone.
    For Samsung – Reset Network Settings:
    From the Home screen, swipe up to access Apps → Settings → Connections → Mobile Networks → Network Operators.
    Turn Select Automatically on or off.
    Alternatively:
    Go to Settings → General Management → Reset → Reset Network Settings.
    Confirm by tapping Reset Settings.
    Ā
    Ā
    Zandile M
    The iD Mobile Team
