Jun 15, 2026 5:11 PM UTC
how call Turkey using UK ID
How can i phone Turkey from UK using my ID MOBILE PHONE NUMBER.  Roaming seems to be switched on but call not allowed
    Jun 15, 2026 6:46 PM UTC
    Hi ​@Rocmo63,
    If you're calling Turkey from the UK, this isn't classed as roaming, so having roaming enabled won't affect your ability to make the call.
    You'll need to dial the number in the correct international format by replacing the leading 0 with +90. For example, 01234 567890 would become 00901234567890 or +90 1234 567890.
    Please be aware that calls from the UK to Turkish numbers aren't included in your standard allowance and will be charged at our international rates. You'll also need to make sure your bill cap is set high enough to allow the call to go through.
    To view or change your bill cap, log in to the iD Mobile app or your online account, go to Bills, and select Manage bill cap. You can increase it to an amount between £0 and £75, depending on your account.
    You can view our international call charges here: https://www.idmobile.co.uk/help-and-support/call-abroad
    Here’s what it will cost to make calls or send texts to someone in Turkey.
    Please note: these are charges only for calling Turkey from the UK. If you are trying to call a different country whilst you are outside of the UK, you will incur roaming charges.
      Pay Monthly
    Calls to mobiles* £0.12
    Calls to landlines* £0.09
    Texts** £0.30
    Picture message (MMS)** £0.30
    * Price per minute
    ** Price per message/text
    If you're still unable to make the call after dialling the number correctly and increasing your bill cap, please let us know what error message you're receiving, and we'll be happy to help further.
