Apr 10, 2026 1:02 PM UTC
how to call spain from uk? how will I be charged?
How do I call Spain from the Uk?
    Kwanele Z
    Apr 10, 2026 1:35 PM UTC
    Hi ​@Canete,
    Thank you for your message.
    To call Spain from the UK, you simply need to dial:
    +34 (Spain country code) + the Spanish number
    or
    00 34 + the Spanish number
    Please make sure your bill cap is set above £0.00, as international calls are not included in your allowance and will be charged from your bill cap.
    Apr 28, 2026 11:43 AM UTC
    can i use minutes/texts to call/text *from* the UK to another UK Mobile that is visiting Spain (a roaming tier 1 country)?
    Apr 28, 2026 12:15 PM UTC
    Hi ​@NeFo,
    Thanks for getting in touch.
    If you’re in the UK and calling or texting a UK mobile number that is currently in Spain, this is treated as a normal UK-to-UK call/text. So it’s free and included in your allowance (minutes/texts), just like usual.
    However, if you’re calling or texting a Spanish mobile number, that is classed as an international call/text, and it wouldn’t be included in your allowance, so charges would apply.
    So in short:
    UK to Spain - UK number roaming in Spain = included in your plan
    UK to Spain - Spanish number = international charges apply
    Everything works the same as if they were still in the UK, as long as the number you’re contacting is a UK number
    If you’re ever unsure about specific destinations or charges, the iD Mobile website has a full breakdown of international rates too which you can access here: https://www.idmobile.co.uk/help-and-support/international-and-roaming-charges
