May 3, 2026 12:24 PM UTC
how to check my roaming usage
How do I know how much data I've used while roaming? Cant seem to find anywhere on the app?
    May 3, 2026 12:50 PM UTC
     Hi ​@Glens26,
    Thanks for getting in touch.
    Kindly note that at this time, there is no way of seeing this, however I can confirm that you can use your data allowance abroad just as you would in the UK. So, if you have an unlimited data plan, you can continue using your data in our free roaming destinations in line with your plan’s allowances.
    May 20, 2026 10:49 PM UTC
    Hi gemma.
    the answer was helpful. I have unlimited data in uk. So is there is a cap on roaming allowance 30gb. If yes. Then how can we check that how much allowance data is left
    thank you
    May 21, 2026 10:49 AM UTC
    Hi ​@Deniseprokopi,
    At the moment, the EU roaming data limit restriction has been lifted until further notice, so you can currently use your normal monthly allowance whilst roaming in included EU destinations.
    This means if your UK plan includes unlimited data, there is currently no separate 30GB roaming cap being applied in the usual way.
    Because of this, there also isn’t a separate EU roaming allowance tracker to monitor remaining roaming data specifically, you would simply continue to see and use your normal plan allowance through the iD Mobile app.
    We’d still recommend keeping an eye on your overall usage in the app and setting your bill cap to £0.00 if you want to avoid any unexpected out-of-plan charges, particularly if travelling near borders or using ferries where your device could connect to a chargeable network.
    Sep 18, 2026 10:57 AM UTC
    ​@Gemma M  Is the roaming allowance restriction still lifted?
    Sep 20, 2026 7:12 AM UTC
    Hi ​@Rlwhittle,
    No, the temporary change has now ended and the EU roaming data limit is back to 30GB.
    This means you can use up to 30GB of your UK data allowance while roaming in our inclusive destinations, subject to our fair usage policy.
    Sep 23, 2026 11:51 AM UTC
    So, is it possible to check how much of the 30GB limit I have used?
    Marquerita T
    Sep 24, 2026 3:36 PM UTC
    Hi ​@Kgjfnt.
    Thank you for your post.
    Kindly note that you can check your overall remaining allowance via the iD Mobile App. Please note that the app tracks your total usage rather than giving a separate, isolated breakdown for roaming versus UK data.
    Marquerita
    The iD Mobile Team
    Sep 25, 2026 12:05 PM UTC
    Hello, so if it gives total usage, how do we know how much was used whilst roaming? Will ID send a message when 80% of 30gb has been used?
    Sep 25, 2026 12:11 PM UTC
    Can't get roaming to work
    Sep 28, 2026 3:57 PM UTC
    Hi ​@Kpsmithcon87,
    I’m sorry to hear you’re having trouble getting roaming to work.
    Could you please let us know which country you’re currently in? Once we know your destination, we can advise you on the correct roaming settings and troubleshooting steps.
    Oct 6, 2026 11:46 PM UTC
    Are there plans to introduce a way to track the 30GB roaming cap?
    Oct 9, 2026 10:22 AM UTC
    Hi ​@Sldlcu,
    Thanks for the suggestion.
    At the moment, there aren't any plans that we're aware of to introduce a tracker for the 30GB roaming data limit within the app.
    That said, it's a useful piece of feedback, and we'd be happy to pass it on to the relevant team for consideration in future improvements.
    Oct 9, 2026 10:59 AM UTC
    Please do. I've seen many community thread/posts about it so it seems there is demand. Now that the 30GB cap is active, it makes no sense to expect your clients to monitor usage autonomously in their phone settings rather than being able to see it in the app like for any other provider (last thing I will rememmebr when I travel is to reset the data measurement on my phone as I step out of the plane.. ) thanks!
    Marquerita T
    Oct 10, 2026 2:01 PM UTC
    Hi ​@Sldlcu.
    Thank you for the follow-up, and for explaining why this matters to you. You’re right that being able to see your roaming usage in the app would be more convenient than checking your phone settings.
    We appreciate you taking the time to share it.
    Marquerita
    The iD Mobile Team
    Oct 11, 2026 12:23 PM UTC
    Hopefully you can implement this soon.
    Oct 13, 2026 2:23 PM UTC
    Hi ​@Richard Evans-Lacey,
    Thank you for the feedback. We really appreciate you taking the time to share your suggestion with us.
    We'll be sure to pass this on and look into it for future improvements.
