How to check roaming data usage?
  • August 15, 2025
  • 555 views
Need to add an area on the app to check data roaming usage. Presently it only shows UK data usage. I want to know how fast I am using the data whilst away from UK which is a different allowance. I can do this on my Spain account with MASMovil.
    Use for forum search feature! This question has been answered several times over the past two or three days.
    Hi ​@TomSea
    Unfortunately it isn’t possible to check how much data you’ve used specifically whilst roaming at this time, we’ll feed the want for the feature back to the team however we don’t have any announcements to make at this time.
    It may be best to see if your device has an inbuilt data tracker and using that.
    TomSeaAuthor
    It would be a good and useful feature for many.
    Hi ​@TomSea,
    Thanks for your feedback, hopefully we can implement this in the future.
    If you require further assistance, please get back to us.
