Jan 27, 2026 12:44 PM UTC
i am going to Switzerland. how can i get cheap calls and data
I am going to Switzerland how do I get cheap calls and data and how do I change my spend block which is on for zero pounds currently
    Zandile M
    Jan 27, 2026 1:03 PM UTC
    Hi ​@Toppy2025
    Thank you for getting in touch with us. If you’re travelling to Switzerland and want to use your phone for calls, texts and data while you’re there, there are a few things to be aware of:
    Switzerland is not part of the EU roaming zone, so roaming charges may apply depending on your plan. To help keep costs low while you’re abroad, here are some options:
    Purchase a roaming add-on / bolt-on before you travel — these typically offer a set amount of data, minutes and texts for use abroad at a fixed cost.
    Use Wi-Fi where possible for data and calls using apps like WhatsApp/FaceTime/Skype.
    Check in-plan roaming allowances — if your plan includes any roaming benefits, these might reduce charges.
    To change your spend Cap limit:
    To change this:
    Log into the iD Mobile app or My iD online portal
    Go to Account Settings → Spend Cap
    Adjust the cap to an amount that suits you (example: £20 or £30)
    Zandile
    Mar 15, 2026 5:22 PM UTC
    Hi Zandile
    I am not clear about data / calls. Is searching the internet under data? What about WhatsApp - does that count as data or calls? I take it that you can still receive calls after your service is up?
    I have just come back from Switzerland and had not taken any action before leaving. Very quickly I received the text saying I was 80% towards my cap and 100% shortly after. It appeared at that time that I could not go on to the app or the internet to change my bill cap - is wi fi the only way if you have run out?
    I see that there is a way to cover this before leaving using the Roam Beyond add ons, but it says ‘get extra data with add ons’ which last for a certain number of days. What are the add ons or is it just data?
    I will need to make a calculation as to how much to purchase before my next trip. Any help welcome. Thanks
    Mar 15, 2026 6:02 PM UTC
    Hi ​@Steve Cirell,
    Kindly note that roaming in Switzerland is not included in our roaming package, so there is no option for making calls free of charge, however you can purchase a data roaming bundle, as mentioned on our website under ‘Roaming Charges’ (https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges)
    The prices for the bundles are as below:
    Data Duration Price
    2 GB 1 day £5
    10 GB 5 days £20
    20 GB 10 days
    £35
    The table below displays how much you’ll be charged for any minutes, texts or data that you use in Switzerland:
    Roaming Pay monthly
    Calls to UK* £2.40
    Calls to Switzerland* £2.40
    Calls received* £2.40
    Texts to Switzerland** £0.60
    Texts to UK** £0.60
    Picture message (MMS) sent** £0.60
    Internet and Data (per MB)*** £1.50
    * Price per minute
    ** Please note: MMS charges vary. For further information, refer to Terms & Conditions. If you joined or upgraded on or before 20th June 2023 the MMS cost is £0.30 per message for Roaming within EU Bands 1 and 2.
    **** The charges below will apply to all Pay-as-you-go customers starting from 1st October 2024. Find out more about the current charges here.
    If you are not looking to get charged more than your monthly line rental, we do recommend setting your bill cap to £0.00.
    If you have any further questions, please do not hesitate to ask, we’re happy to help.
