Oct 2, 2026 8:42 AM UTC
"I bought the 3GB data add-on thinking it works in EU roaming but it doesn't. Please refund me the £8 — I need roaming data."
    Oct 3, 2026 9:40 AM UTC
    Hi ​@Hazem86,
    I’m sorry for the confusion regarding the data add-on.
    Unfortunately, once an add-on has been purchased, it activates immediately and cannot be cancelled, transferred or refunded.
    If you’re travelling within one of our 50 Inclusive Roaming destinations, you don’t need to purchase a separate roaming data add-on. You can use the data included within your normal iD Mobile monthly allowance, up to the 30GB Inclusive Roaming limit.
    You can check whether your destination is included and find more information about roaming here:
    https://www.idmobile.co.uk/help-and-support/roaming
    https://www.idmobile.co.uk/help-and-support/eu-roaming
