Apr 8, 2026 3:47 PM UTC
i have no data in lanzarote, please help
Landed yesterday in Lanzarote and received a message regarding roaming, however my data isn't working while out here.
    Lamiya C
    Apr 11, 2026 9:50 AM UTC
    Hi ​@DiogoL94 ,
    I’m really sorry to hear your data isn’t working while you’re abroad,  I understand how important it is to stay connected when you’ve just arrived.
    Thanks for letting us know you did receive the roaming message, that’s a good sign that roaming has started correctly on your account.
    Could you please try the following troubleshooting steps:
    • Make sure Data Roaming is switched ON in your phone settings
    • Turn Airplane Mode on for 30 seconds, then switch it off again
    • Manually select a local network in Lanzarote (try each available one if the first doesn’t connect)
    • Restart your phone fully
    • Check that Mobile Data is enabled
    • Ensure your APN settings are set to default/automatic
    If it still isn’t working, it may help to reset the network settings on your device (this will not delete your data, but will reset saved Wi-Fi and network connections).
    Lamiya
