Jun 20, 2026 7:14 PM UTC
im going to belgium for 3 days can i use my phone there?
I'm am going to belgium for 3 days cam I use my data and minutes & messages in belgium while I'm there?
    Decembersangel72
    Gold Contributor
    Gold Contributor
    Jun 20, 2026 10:37 PM UTC
    Hi ​@Yas2014
    Yes, you can use your phone in Belgium with iD Mobile. Belgium is included in their European roaming zone (Band 1), meaning your standard UK allowances for calls, texts, and data will work at no extra cost, subject to a fair-use policy.
    To ensure everything works smoothly when you arrive, follow this quick checklist:
    Check Your Plan: You have access to your regular UK allowances, but data is subject to a fair use cap of up to 30GB per month.
    Enable Roaming on Your Phone: Go to your device's settings and turn Data Roaming ON.
    Activate Roaming on Your iD Account: You must toggle Roaming ON in the iD Mobile App or via your online account dashboard.
    Manual Network Selection: Connect to an iD Mobile partner network upon landing, go to your network settings and manually select the one that supports customers of iD Mobile
    https://community.idmobile.co.uk/roaming%2D76/which%2Droaming%2Ddestinations%2Dare%2Dincluded%2Din%2Dmy%2Dplan%2D45112
    Please be aware that if you are near the coast and you have your connection set to ‘Automatic’ then it may connect to a maritime (satellite) signal and this will be costly.
    https://www.idmobile.co.uk/help-and-support/roaming
    You can also set a cap for your monthly bill that ensures that if your phone inadvertently connects to a ‘payable’ network then it won’t work (as you won’t have the £ to pay for it):-
    https://www.idmobile.co.uk/help-and-support/capping
    Hope this helps x
    Jun 22, 2026 10:26 AM UTC
    Hi ​@Yas2014,
    Belgium is an inclusive roaming destination with iD Mobile, so you won't need to purchase any additional data add-ons. You'll be able to use your UK allowance for your data, minutes and texts while you're there, subject to our fair usage policy.
    To help prevent any unexpected out-of-plan charges, we'd recommend setting your bill cap to £0.00 before you travel.
    To do this:
    • Log in to the iD Mobile app or your online account.
    • Go to Bills.
    • Select Manage Bill Cap.
    • Set the bill cap to £0.00.
    To get the best possible service while you're in Belgium, please make sure you're connected to one of our roaming partners:
    • Belgacom
    • Telenet Group NV/SA
    • Orange
    On iPhone:
    • Go to Settings > Mobile Service (or Mobile Data) > Network Selection.
    • Turn Automatic off.
    • Wait for the available networks to appear and select one of the partners listed above.
    On Android:
    • Go to Settings > Connections > Mobile Networks > Network Operators.
    • Turn Select Automatically off.
    We hope you have a fantastic trip!
