Feb 6, 2026 11:02 AM UTC
im going to india . how much will it cost roaming to india
Hi, I’m going India tomorrow, can I use my number there ?
    Feb 6, 2026 1:28 PM UTC
    Hi ​@Baljit,
    As you are aware, roaming is not included in India, however you can now buy a data-only add-on to stay connected while you're in India. Use your data to browse, stream, and keep in touch with friends and family at all times. To get an add-on, simply log in to the iD Mobile app or https://my.idmobile.co.uk/.
    Data Duration Price
    2 GB 1 day £5
    10 GB 5 days £20
    20 GB 10 days £35
    Tip: To avoid out-of-plan charges when you land, it's best to purchase your Roam Beyond add-on while you're still in the UK. Alternatively, once you reach your destination, keep mobile data turned off until you can connect to Wi-Fi and buy an add-on.
    Any extra charges for roaming, using calls, texts or data in India can be found on our website: https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges
    Roaming Pay monthly
    Calls to UK* £2.40
    Calls to India* £2.40
    Calls received* £2.40
    Texts to India** £0.60
    Texts to UK** £0.60
    Picture message (MMS) sent** £0.60
    Internet and Data (per MB)*** £1.50
    * Price per minute
    ** Please note: MMS charges vary. For further information, refer to Terms & Conditions. If you joined or upgraded on or before 20th June 2023 the MMS cost is £0.30 per message for Roaming within EU Bands 1 and 2.
    **** The charges below will apply to all Pay-as-you-go customers starting from 1st October 2024. Find out more about the current charges here.
    iD Mobile Social Media Team
