Hi @GRK,
Yes, tethering (personal hotspot) is permitted while roaming in our inclusive roaming destinations, so you can use your phone's hotspot feature to share your mobile data connection with other devices.
However, please be aware that when roaming, your data allowance is subject to a 30GB roaming data limit. Once this limit has been reached, further roaming data usage may be restricted or chargeable depending on your plan and roaming terms.
If your hotspot wasn't working during your recent trip, we'd recommend checking the following if it happens again:
- Make sure Personal Hotspot is enabled on your device.
- Confirm that mobile data and data roaming are switched on.
- Restart your phone.
- Reset your network settings.
- Check how much roaming data you've used, as reaching the roaming allowance could affect hotspot usage.
