May 20, 2026 7:53 PM UTC
Making calls/texts in Australia with UK mobile
Travelling to Australia in June and want to use UK mobile (iD Mobile account) for phone and text calls.
Procedure and charges for data roaming are clear but making calls/texts is a higher priority for me.
How do I arrange this and what are the charges?
    May 21, 2026 10:28 AM UTC
    Hi ​@Diwali,
    Australia is in iD Mobile’s Roam Beyond zone, which means your UK allowance won’t work there. It’s also important to note that the available add-ons are data-only.
    While these are suitable for things like maps or browsing, they don’t include calls or texts. Any standard calls or SMS will be charged separately at out-of-plan rates.
    How the Roam Beyond add-ons work:
    • You can purchase a data-only bundle via the iD Mobile app or your online account.
    • The add-on starts immediately upon purchase and lasts for a fixed duration.
    • Once it expires, you’ll need to buy another add-on or you’ll be charged standard roaming rates (if your bill cap allows this).
    • Your regular UK allowance (minutes and texts) is not included while in Australia.
    How to check if you have a bill cap in place:
    • To view or change your bill cap, log in to the iD Mobile app or your online account, go to the Bills section, and select Manage bill cap.
    • You can adjust this using the slider or by entering an amount (between £0 and up to £75.00, depending on your account type).
    Add-on options: (For data only)
    Data Duration Price
    2 GB 1 day £5
    10 GB 5 days £20
    20 GB 10 days £35
    Standard roaming charges (without an add-on):
    The table below displays how much you’ll be charged for any minutes, texts or data that you use.
    Roaming Pay monthly
    Calls to UK* £1.68
    Calls to Australia* £1.68
    Calls received* £1.50
    Texts to Australia** £0.42
    Texts to UK** £0.42
    Picture message (MMS) sent** £0.60
    Internet and Data (per MB)*** £0.30
    * Price per minute
    ** Please note: MMS charges vary. For further information, refer to Terms & Conditions. If you joined or upgraded on or before 20th June 2023 the MMS cost is £0.30 per message for Roaming within EU Bands 1 and 2.
    For more information, you can visit: https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges.
    Tip:
    Depending on how long you’re staying, it may be more cost-effective to get a local SIM in Australia. Since the bundles last a maximum of 10 days, you may need to purchase multiple add-ons, which can become expensive.
    If you have any further questions, feel free to pop us a message on live chat - https://www.idmobile.co.uk/live-chat - we are more than happy to answer any further questions you may have.
