Jul 12, 2026 8:39 AM UTC
my roaming in Poland doesn’t work
My roaming in Poland doesn’t work for data. I have ticked all the right boxes at still I cannot browse anything. Is there any problem on your end?
    Jul 13, 2026 10:00 AM UTC
    Hi ​@MacF,
    We're sorry to hear you're having trouble using your data while roaming in Poland.
    First, could you check that your phone is connected to one of our roaming partners:
    • Orange
    • Play
    • Plus
    • T-Mobile
    You can manually select a network using the steps below.
    For iPhone:
    1. Go to Settings > Mobile Service (or Cellular).
    2. Tap Network Selection.
    3. Turn Automatic off.
    4. Wait for the available networks to appear and select Orange, Play, Plus or T-Mobile.
    5. Restart your phone after connecting.
    For Android:
    (Steps may vary slightly depending on your device.)
    1. Go to Settings > Connections or Network & Internet.
    2. Tap Mobile Networks.
    3. Select Network Operators.
    4. Turn Select Automatically off.
    5. Choose Orange, Play, Plus or T-Mobile from the list.
    6. Restart your phone.
    If you're still unable to use data after trying the above, please let us know:
    • The make and model of your phone.
    • Whether calls and texts are working.
    • Whether you've received any roaming welcome text messages since arriving in Poland.
    We'll be happy to help further.
