Apr 29, 2026 3:13 PM UTC
roam beyond turkey not working
I bought roam beyond it's say it's active. But internet doesn't work!
Bill cap is over £0 sent at £25
Roaming is on
What's the problem?
    Owethu M
    Apr 29, 2026 4:02 PM UTC
    Hi ​@mazmat,
    I’m sorry to hear that you’ve been unable to use your roaming add-on.
    To ensure the add-on works correctly while you are in Turkey, please make sure of the following:
    • Your Bill Cap is set to £0, as roaming add-ons may not function correctly if a higher cap is in place
    • Your device is connected to one of our partner networks in Turkey, which are AVEA or Turkcell
    • And roaming needs to be active on the handset and app
    You can manually select a network by going to your phone’s network settings, turning off automatic selection, and choosing one of the supported networks listed above.
    Owethu
