Jun 16, 2026 1:13 PM UTC
roaming and international
Can I use my plan in poland
    Owethu M
    Jun 16, 2026 1:19 PM UTC
    Hi ​@Nusi84,
    Thank you for your message.
    Yes, you can use your iD Mobile plan in Poland, as it is included within our standard EU roaming destinations.
    This means you can use your UK allowances (calls, texts and data) while travelling in Poland, subject to our Fair Usage Policy.
    Before you travel, we recommend:
    • Ensuring Roaming is switched ON in the iD Mobile app
    • Turning on Data Roaming in your handset settings
    • Checking that your Bill Cap is set above £0 to allow roaming usage
    To set your Bill Cap:
    1. Open the iD Mobile app
    2. Go to My Account
    3. Select Bill Cap
    4. Set it to your preferred limit (£0)
    If you have any issues while abroad, please connect to a local partner network and restart your handset to help it register correctly. Below are our roaming partners please click on the link:
    https://community.idmobile.co.uk/roaming%2D76/which%2Droaming%2Ddestinations%2Dare%2Dincluded%2Din%2Dmy%2Dplan%2D45112
    Owethu
