Jun 11, 2026 10:40 AM UTC
roaming Beyond
If you take out a 10 day roaming plan does the plan work on 10 consecutive days or only on the days you use phone?
    Gemma MAnswer
    Jun 11, 2026 10:43 AM UTC
    Hi ​@Stevec1966,
    Thanks for getting in touch.
    The 10-day roaming add-on runs for 10 consecutive days from the date and time it is purchased.
    It doesn't pause on days when you don't use your phone, and any unused allowance won't roll over beyond the expiry date.
    For example, if you purchase the add-on on 1 July, it will expire 10 days later regardless of how many days you actually use it during that period.
    Gemma MAnswer
    Hi ​@Stevec1966,
