Jun 17, 2026 4:11 PM UTC
Roaming in Canada not working
roaming in Canada not working despite purchasing an add on for £35
    Lamiya C
    Jun 19, 2026 10:57 AM UTC
    Hi ​@Lynn2,
    I completely understand your frustration, especially as you’ve purchased an add-on and are still unable to use roaming in Canada. That’s not the experience we want you to have, and I’m really sorry for the inconvenience caused.
    To help get this sorted, please try the following steps:
    Restart your phone completely (turn it off for 5–10 minutes, then back on)
    Ensure Data Roaming is switched ON in your device settings
    Go to Network Selection and set it to Automatic, or manually try a local Canadian network
    Check that Mobile Data is enabled and airplane mode is OFF
    If possible, try toggling between 3G/4G/5G in network settings
    If using an eSIM, ensure it is the active line for data
    Also, please check:
    You have the correct £35 roaming add-on active in the iD Mobile app
    You’ve restarted the device after arriving in Canada
    Lamiya
