Sep 20, 2026 2:03 PM UTC
roaming in dublin and not wirking
Hi I am in dublin and my roaming is not working.
    Marquerita T
    Sep 21, 2026 6:07 PM UTC
    Hi ​@Redhinx.
    Thank you for your post, and I'm sorry to hear your roaming isn't working in Dublin. I understand how inconvenient that is when you're away.
    Could you try the following:
    • Restart your device to refresh your connection to the network.
    • Turn Airplane Mode on for around 30 seconds, then turn it off again.
    • Check that your mobile data is switched on
    • Remove your SIM card, gently wipe it with a clean, dry cloth, reinsert it, and restart your device.
    • Check that your device software is fully up to date.
    • Reset your network settings to refresh your device's connection to the network.
    • Manually connect to Three in your phone's network settings.
    Marquerita
    The iD Mobile Team
