May 26, 2026 6:41 AM UTC
Roaming issues in Turkey with adds-on
I have purchased a £35 add on for Turkey but can't connect to Internet using data despite following all the steps suggested in both the community articles and faqs/troubleshooting suggestions - change network providers resetting network settings etc. Could you please help?
    Lamiya C
    May 26, 2026 10:19 AM UTC
    HI ​@Michelem,
    I’m really sorry you’re having trouble getting connected in Turkey, especially after already trying the troubleshooting steps. I completely understand how frustrating that must be.
    Please could you try the following quick checks as well:
    Make sure Data Roaming is turned ON
    Restart the phone after the add-on was applied
    Manually connect to another available network in Turkey
    Ensure mobile data is enabled and Wi-Fi is turned off during testing
    Check your APN settings are set to default/iD Mobile
    If it’s still not working after this, please let us know.
    Lamiya
    MichelemAuthor
    May 26, 2026 3:29 PM UTC
    Thanks, afraid still doesn't work
    Hosai W
    May 27, 2026 11:11 AM UTC
    Hi ​@Michelem,
    Thank you for getting in touch with us, please can you try and connect to Turk Telekom.
    Hosai
    MichelemAuthor
    May 27, 2026 1:40 PM UTC
    It now works with Turk Telekom, strange as it wasn't before. Thanks
    Hosai W
    May 28, 2026 2:36 PM UTC
    Hi ​@Michelem,
    Thank you for getting back to us, I am glad that your data services are now working.
    Hosai
