May 30, 2026 8:39 AM UTC
Roaming not working in Turkey
Hi, I brought £20 of roaming as an add on. But my internet is still not working in turkey. I need it working asap for work related purposes
    Owethu M
    Jun 1, 2026 3:35 PM UTC
    Hi ​@Veer1234,
    We're sorry to hear that you're unable to use your data in Turkey despite purchasing a £20 roaming add-on. We understand how important it is to get connected, especially when you need the service for work.
    Please try the following troubleshooting steps:
    • Ensure Roaming is enabled on your iD Mobile account via the app:
      • Log in to the iD Mobile app
      • Select Services
      • Ensure Roaming is switched ON
    • Ensure your Bill Cap is set to £0:
      • Open the iD Mobile app
      • Go to Services
      • Select Manage Bill Cap
      • Set the Bill Cap to £0
    • Make sure Data Roaming is enabled in your handset settings
    • Restart your handset
    • Turn Airplane Mode ON for 60 seconds, then OFF again
    • Manually search for and connect to an available partner network in Turkey
    Please note that roaming add-ons are non-refundable once purchased.
    If you have completed all of the above and your data is still not working, please contact us via Live Chat or send us a direct message through our social media platforms so that we can investigate this further for you.
    Owethu
