Dec 25, 2025 2:40 AM UTC
Roaming on Turkey with £20 add on not working
I bought the add on day one after receiving the welcome to Turkey message. Connected to Turkcell and Vodafone TR.  Both show signal, but then I get an exclamation mark ❗ on the signal.
I have a Google Pixel. I then followed the steps to fix it. Checked the APN. Reset network settings but to no avail.
I still get no Internet even though it says it's connected.
I've got 4 more days left.  I doubt it will connect. I think I need a refund.
I roamed in Greece earlier this year and it worked perfectly.
    Hosai W
    Hosai WAnswer
    Dec 26, 2025 12:33 PM UTC
    Hi ​@Iancowley111
    I am glad that you have managed to get the services working as Turk Telecom would have been the one I would suggest to you, there should not be any charges incurred if you do not use out of plan services.
    Hosai
    Dec 25, 2025 11:28 AM UTC
    I've found that the only network I can connect to is Turk Telecom.
    Which is not on IDs provider list so I may be charged.
    Hosai W
    Hosai WAnswer
    Hi ​@Iancowley111
    Hosai
    Dec 27, 2025 8:17 AM UTC
    Hi ​@Iancowley111
    Hosai
    I answered my own question by trying every provider. Wasn't sure if I would be charged and after using Google maps for a bit I check my usage and it went down to 9.9gb. Checked again later and it went down again.
    I read somewhere that ID was partnered with Turkcell and a one beginning with A so was wary of trying others in case I was charged.
    So advice to people struggling with roaming in Turkey. Try Turk Telecom or the other providers to see which one sticks.
