Jan 24, 2026 11:18 AM UTC
Roaming settings - APN for iphone?
Hello,
just moved to ID and all gone smoothly. But I am a little anxious about roaming.
there’s a lot of threads where roaming didn’t quite work for users even if they “enabled roaming” on their phone and in their ID account.
my iPhone (iPhone 16 pro max) doesn’t have the ability on ID to enter APN settings. I’ve done this with previous providers to ensure roaming was set up.
I’ve deleted network settings but this still doesn’t give me an APN menu.
it may be that times and capability have changed and if your phone is working for calls, FaceTime, I mobile data, OTP etc that you are all good.
anyone else in the position where they can’t access the APN menu but roaming has been ok for them?
thank you
    WelshPaulAnswer
    Jan 24, 2026 9:30 PM UTC
    Yes! 👍🏻
    Jan 24, 2026 11:32 AM UTC
    Hi ​@MiloMc,
    We are so sorry to hear that you are concerned about your roaming services, however we would not be able to troubleshoot without you being in the country that you are roaming in.
    The best advice that we are able to give you at this time is to make sure that roaming is enabled, and when reaching your destination, make sure that you are connected to the correct partnering networks or try doing a network reset when you arrive. If you do face any issues or have any questions, please do not hesitate to get in touch with us directly and we would be more than happy to assist you.
    Jan 24, 2026 2:32 PM UTC
    APN settings are hidden by iD Mobile on iOS and can’t be viewed, modified or deleted.
    MiloMcAuthor
    Jan 24, 2026 9:26 PM UTC
    thank you - does this generally mean that you are all set for roaming so long as your phone and account says “yes”
    thanks
    WelshPaulAnswer
    Yes! 👍🏻
