roaming when overseas - no connection
  • November 15, 2025
  • 20 replies
  • 304 views
I can’t get 4/5g when overseas.  The id instructions say to go to “mobile services” on my phone but this doesn’t exist?
    Decembersangel72
    Gold Contributor
    Gold Contributor
    November 16, 2025
    Hi ​@sturgeonben
    Could you please let us know what phone you are having trouble with so that we can give you the correct advice.
     x
    Hi.  I phone 15
    It’s located in the settings menu.
    Then Cellular in your case.
    Thanks.  My roaming is on.  But also I have “add e sim”.  I had added last week - perhaps it didn’t work?   When I try again it says eSIM no longer active
    The option to add an eSIM is normal. You can add more than one eSIM. If the eSIM hadn’t installed correctly, you wouldn’t have a signal.
    Ok.  Thanks.  So if my roaming is on why no 4/5G?
    What do you mean no 4G/5G? You have two bars of signal in the screenshot above so you’re getting a service of some kind.
    That is analogue phone signal   When I’m out I cannot connect to the internet via 4/5G.  I can only connect with WiFi.
