Jul 10, 2026 4:08 PM UTC
roaming wont work
Hi, I cannot get roaming to work, I am in Spain, my friend is also ID and hers will work, I’ve tried all the trouble shooting options
    Jul 11, 2026 7:07 AM UTC
    Hi ​@Coop17,
    We're sorry to hear you're still having trouble with roaming in Spain.
    If you've already tried the basic troubleshooting, we'd recommend trying a manual network selection and a network settings reset.
    Our roaming partners in Spain are:
    • Vodafone
    • Telefónica
    • Xfera
    • Orange
    For iPhone:
    Manual network selection
    1. Go to Settings > Mobile Service (or Cellular).
    2. Tap Network Selection.
    3. Turn Automatic off.
    4. Wait for the available networks to load, then try connecting to Vodafone, Telefónica, Xfera, or Orange.
    Reset Network Settings
    1. Go to Settings > General.
    2. Tap Transfer or Reset iPhone.
    3. Select Reset.
    4. Tap Reset Network Settings.
    For Android:
    1. Go to Settings > Connections (or Network & Internet).
    2. Tap Mobile Networks.
    3. Select Network Operators.
    4. Turn Select Automatically off.
    5. Wait for the available networks to load, then try connecting to Vodafone, Telefónica, Xfera, or Orange.
    1. Go to Settings.
    2. Tap General Management or System.
    3. Select Reset.
    4. Tap Reset Network Settings and confirm.
    If you're still unable to connect after trying all of the above, please contact our Customer Service team via Live Chat so they can investigate further. You can contact them here: https://www.idmobile.co.uk/live-chat
