Nov 3, 2026 3:07 PM UTC
Turkey Roaming Not Working
Hello, I bought a roaming add on for Turkey but it doesn't seem to work. I tried all the FAQ advice, changing the network, checking roaming is on etc, but it still won't work. Can I get a refund please?
    Nov 6, 2026 1:08 PM UTC
    Hi ​@NSutcliffe,
    I'm sorry to hear you're having trouble using the roaming add-on in Turkey.
    Just to check, are you still in Turkey, or have you now returned to the UK?
    If you're still in Turkey, we may be able to suggest some further troubleshooting. If you've already returned to the UK, it won't be possible to troubleshoot the roaming issue, but we can point you in the right direction regarding the add-on.
    Nov 8, 2026 8:44 AM UTC
    Hello, thanks for the reply. We’re back in the UK now. In the end my wife had to get an add on with her provider. If you could refund that would be great. Thanks
