Apr 17, 2026 6:56 AM UTC
unlimited plan and roaming
If my plan has unlimited data calls and texts, is this still unlimited in Germany?
it’s not clear on website and just says 30gb fair usage.
thanks
    Owethu M
    Owethu MAnswer
    Apr 17, 2026 1:36 PM UTC
    Hi ​@suzyblue5,
    I can see why that’s confusing the wording on this isn’t very clear, so I’ll break it down properly.
    Using your plan in Germany (Roam Free destination)
    Germany is included in iD Mobile’s Roam Free destinations, so:
    • Your minutes and texts remain unlimited (as per your UK plan)
    • You can use them just like you would in the UK
    Owethu
    Owethu M
    Owethu MAnswer
    Hi ​@suzyblue5,
    Owethu
    Jun 6, 2026 11:39 AM UTC
    Hello,
    I am an unlimited data/text/calls plan in country of residence UK
    Will be travelling to Gran Canaria next week - do i have roaming?
    Is it unlimited on data/calls/txt whilst in Gran Canaria?
    The website as stated by others is confusing me as well.
    Hopefully someone will clarify
    Pete
    Jun 7, 2026 10:37 AM UTC
    Hi ​@topov1309
    Gran Canaria is one of the islands in Spain, so you will be able to roam as if you were in the UK, using your standard allowances.
    I would recommend setting your bill cap to £0 before you travel to avoid any unexpected charges while roaming.
    -Michael Z
    Jun 8, 2026 9:52 AM UTC
    Thanks Michael,
    so as I am on unlimited everything then no problems 🤞
    Jun 8, 2026 9:54 AM UTC
    Hi ​@topov1309
    That is correct. You will roam with no issues.
    -Michael Z
    Oct 1, 2026 11:59 AM UTC
    Why I don’t receive text massage while I am in Germany ?
    Oct 1, 2026 12:04 PM UTC
    Hello,
    Can I use my date in Germany - do i have roaming?
    Is it unlimited on data/calls/txt whilst in Germany?
    Oct 1, 2026 7:38 PM UTC
    I have unlimited plan so what do I need to do to go to USA and Hawaii
    Oct 2, 2026 9:10 PM UTC
    Hi ​@Larcs,
    Kindly note that USA is in iD Mobile’s Roam Beyond zone, which means your UK allowance won’t work there. It’s also important to note that the available add-ons are data-only.
    While these are suitable for things like maps or browsing, they don’t include calls or texts. Any standard calls or SMS will be charged separately at out-of-plan rates.
    How the Roam Beyond add-ons work:
    • You can purchase a data-only bundle via the iD Mobile app or your online account.
    • The add-on starts immediately upon purchase and lasts for a fixed duration.
    • Once it expires, you’ll need to buy another add-on or you’ll be charged standard roaming rates (if your bill cap allows this).
    • Your regular UK allowance (minutes and texts) is not included while in USA.
    How to check if you have a bill cap in place:
    • To view or change your bill cap, log in to the iD Mobile app or your online account, go to the Bills section, and select Manage bill cap.
    • You can adjust this using the slider or by entering an amount (between £0 and up to £75.00, depending on your account type).
    Add-on options:
    Data Duration Price
    5 GB 1 day £10
    10 GB 5 days £20
    20 GB 10 days £35
    Standard roaming charges (without an add-on):
    The table below displays how much you’ll be charged for any minutes, texts or data that you use.
    Roaming Pay monthly
    Calls to UK* £1.68
    Calls to United States (USA)* £1.68
    Calls received* £1.50
    Texts to United States (USA)** £0.42
    Texts to UK** £0.42
    Picture message (MMS) sent** £0.60
    Internet and Data (per MB)*** £0.30
    * Price per minute.
    ** Price per message / text.
    *** Data is charged or deducted in one kilobyte (KB) increments and any part KB used will be rounded up to the nearest KB.
    For more information, you can visit: https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges.
    Tip:
    Depending on how long you’re staying, it may be more cost-effective to get a local SIM in USA. Since the bundles last a maximum of 10 days, you may need to purchase multiple add-ons, which can become expensive.
    If you have any further questions, feel free to let us know or pop us a message on live chat - https://www.idmobile.co.uk/live-chat - we are more than happy to answer any further questions you may have.
