Sep 26, 2026 7:00 PM UTC
Using minutes while on holiday
When on holiday in Italy, will I be able to use my phone to call a uk landline number or will there be additional charges ?
    Decembersangel72
    Gold Contributor
    Gold Contributor
    Sep 27, 2026 12:16 AM UTC
    Hi ​@Georgia_emily
    As Italy is part of the ‘Roam free’ inclusive destinations for iD Mobile you can use your call and text allowance to contact UK numbers.  Receiving calls or texts while in Italy is also completely free.
    https://www.idmobile.co.uk/help-and-support/roaming
    You can use also your data allowance, though a fair usage cap of 30GB per billing month applies if your total UK data plan is higher than 30GB.
    You also need to ensure that Roaming is enabled on your phone and within your iD Mobile account:-
    https://www.idmobile.co.uk/help-and-support/eu-roaming
    Hope this helps x
    Sep 28, 2026 12:16 PM UTC
    Hi ​@Georgia_emily,
    Yes, Italy is one of iD Mobile’s Inclusive Roaming destinations, so you can use your remaining inclusive minutes to call standard UK landline and mobile numbers without additional charges.
    Please note that certain numbers are blocked while roaming, including 080 freephone numbers, 084/087 non-geographic numbers and premium numbers such as 09 and 118.
    You can find more information about Inclusive Roaming here: https://www.idmobile.co.uk/help-and-support/eu-roaming
