Mar 12, 2026 3:01 PM UTC
using my phone in fhe USA
Hi, I am travelling to the USA on 30th March until 20th April 2026. Am I able to use my phone and data with no extra charge or do I need to buy an add on?
    Zandile M
    Mar 12, 2026 5:53 PM UTC
    Hi ​@bryw
    When travelling to the USA, your UK allowance (minutes, texts, and data) is not included, so using your phone there may result in additional charges unless you purchase a roaming add-on. We recommend purchasing a USA add-on in order to use your services while abroad, and please make sure your spending cap is set to £0.00 to avoid any unexpected charges.
    You can view the roaming charges and available add-ons using the link below:
    Zandile
    The iD Mobile Team
