May 7, 2026 4:08 PM UTC
using phone abroad
I am going to Tenerife and can’t find anywhere that’s tells me if I can use my phone or need to buy add on
    Owethu M
    May 7, 2026 4:32 PM UTC
    Hi ​@Cath1203,
    Good news when travelling to Tenerife, you will be able to use your normal UK allowances with iD Mobile, so you do not need to purchase a roaming add-on for standard usage there.
    📶 Before you travel, please make sure:
    • Data Roaming is switched ON in your handset settings
    • Your Bill Cap is not set to £0, as this can sometimes restrict roaming services
    You can check and change your Bill Cap in the iD Mobile app:
    1. Open the app
    2. Go to Billing
    3. Select Bill Cap
    4. Adjust the amount if required
    📡 Recommended networks in Tenerife
    For the best roaming experience, please connect to one of our partnering networks:
    • Yoigo
    • Movistar
    You can manually select these in:
    • Settings → Mobile Network → Network Selection → Turn OFF automatic → Choose network manually
    Owethu
