May 4, 2026 10:01 AM UTC
what counts as data for Roam Beyond addons? ,
I am going to Indonesia and China
What happens to a roam beyond arson when changing countries?
since texts are excluded from roam beyond adding, how is whatsapp treated? how is messenger treated?
    May 4, 2026 12:49 PM UTC
    Hi ​@mayoroftavullia,
    The Roam Beyond data add-on allows you to use data in countries outside of our 50 inclusive EU roaming destinations. You will need to purchase the relevant add-on for the country you are visiting.
    Apps such as WhatsApp and Messenger use data, so they will work as normal once the Roam Beyond data add-on has been activated.
    -Michael Z
    May 4, 2026 1:23 PM UTC
    thanks
    I also learned that a roam beyond add-on is good in only one country, so travellers visiting more than one country need to buy new add-ons as they move from country to country
    May 4, 2026 4:12 PM UTC
    That’s correct. If you are visiting more than one country and they are not included within our roaming zones, you will need to purchase a separate add-on for each country you visit.
    Michael Z
    May 4, 2026 4:37 PM UTC
    it’s also true that activity on whatsapp and messenger counts as data, rather than text, according to your colleagues in help service
    that will be convenient
    MZone
    May 5, 2026 8:14 AM UTC
    That’s because WhatsApp and messenger use data to send the messages rather than using SMS.
    May 6, 2026 11:25 AM UTC
    We can confirm that WhatsApp would work with roam beyond data, and if you are referring to Facebook Messenger, then yes, that will also work with roam-beyond data. Anything that requires normal data will work, if it requires minutes or counts as a text, it is not included, such as iMessage or SMSing.
