Jun 3, 2026 8:31 PM UTC
when does eu roaming reset
Really struggling to find clear information anywhere on the website regarding this.
I understand I can spend 63 days roaming in the EU within a 4 month period for no additional fees.
If I travel on 1 January 2027 and spend 63 days abroad returning on Friday 5 March. Am I correct in saying my 4 month period will reset from exactly 4 months from 1 January 2027 ie. From 4 May 2027 and i can then use a further 63 days over the next 4 month period?
    Jun 4, 2026 3:08 PM UTC
    Hi ​@Cantfindanswers,
    Thanks for getting in touch.
    To clarify: Your data allowance refreshes on your monthly bill cycle date, so this is when your UK allowance (including any eligible roaming usage) resets each month.
    Separately from this, EU roaming is also subject to a fair usage policy, which is designed to ensure roaming is used in line with occasional travel rather than permanent use abroad.
    This fair usage policy may take into account factors such as:
    • How much of your usage is consistently happening abroad
    • How often and for how long you are roaming
    • Your overall usage pattern over time
    As a result, even though your allowance refreshes monthly on your bill cycle, roaming usage can still be monitored under fair usage rules across a longer period.
    You can read more about this here: https://www.idmobile.co.uk/help-and-support/eu-roaming/fair-usage-policy
    If you’d like, our Live Chat team can also check your specific account and confirm how this applies to your usage.
    Jun 4, 2026 6:54 PM UTC
    Hi, yes could you please advise how I can access the live chat? No option is showing on my side.
    I’m still finding the policy extremely confusing, and at times it feels deliberately convoluted. As it’s advertised as allowing 63 days within a 4 month period, it would seem logical that this should reset once that 4 months has passed. However, I haven’t yet received a definitive or straightforward explanation confirming this.
    I would really appreciate a clear clarification on how the reset period works.
    Jun 5, 2026 11:24 AM UTC
    Any update please? Please can you connect me with live chat
    Lamiya C
    Jun 6, 2026 1:04 PM UTC
    HI ​@Cantfindanswers,
    Thanks for your message, I’m really sorry for the confusion around this, I understand you want a clear answer.
    You can reach our Live Chat team here:https://www.idmobile.co.uk/live-chat
    Scroll down and click “Chat with us” (you may need to accept cookies for it to appear).
    Lamiya
    Jun 6, 2026 4:00 PM UTC
    Hi your 'live chat' are also unable to answer this simple question. It seems nobody knows the official policy. How can this be escalated to management?
    Jun 7, 2026 10:55 AM UTC
    If over a 4-month period you spend 63 days or more in our free roaming destinations, you may be subject to additional charges. This is because our Fair Usage Policy only resets once we can see that you are no longer permanently roaming, based on your usage patterns. This typically aligns with your data refresh date.
    For example, if you leave on 1 January 2027 and spend 63 days abroad, returning on 5 March, charges will not automatically reset. If you continue roaming beyond the 63-day allowance, you may be billed accordingly. However, if we observe that you are no longer roaming for a sustained period (for example, a month), the allowance may reset.
    If we notice that you may not be following our Fair Usage Policy or that your usage is outside our Terms and Conditions, we may temporarily restrict your account.
    We will always notify you 14 days in advance before any additional charges are applied, to help avoid unexpected costs. Any additional roaming charges applied to your plan will be communicated to you at that time.
    -Michael Z
    3.2p per minute per call
    1p per text
    10p
    per MB of data
