Dec 6, 2025 3:05 PM UTC
why does my roaming keep stopping despite being on unlimited plan
Has anyone else had this problem?
    Lamiya C
    Dec 6, 2025 3:51 PM UTC
    Hi ​@Fruit
    What would you like to be assisted with?
    Lamiya
    FruitAuthor
    Dec 6, 2025 8:33 PM UTC
    I’d like my data roaming to work like it should. It works briefly each day then stops, like it’s been capped, but I have unlimited data contract
    Lamiya C
    Dec 8, 2025 11:07 AM UTC
    Hi ​@Fruit ,
    , I’m really sorry to hear you’re having issues with your data roaming. Even on an unlimited plan, iD Mobile has a roaming fair-usage limit (up to 30GB), and roaming can also be affected if settings or network selection aren’t quite right.
    Quick things to check:
    • Make sure Data Roaming is switched ON
    • Turn Airplane Mode off and restart your phone
    • Try manually selecting a network in your phone settings
    • Check your APN is set to:
    APN: id | Name: iD
    Lamiya
