Sep 13, 2026 5:50 AM UTC
Will i lose my full roaming data if i upgrade or downgrade my plan
I want to change my plan, but i joined before 2023, so all my data can be used for roaming, if i change the plan now, will i lose that ability (if ID decides to stop the promotion for no roaming cap)
    Marquerita T
    Sep 13, 2026 12:23 PM UTC
    Hi ​@Jetsky.
    Thank you for your post. It actually depends on the size of the new plan you move to, rather than being tied to a specific promotion:
    If your new plan is under 30GB, you'll be able to use your full monthly UK allowance while roaming, so on a 10GB plan, for example, all 10GB would be usable abroad.
    If your new plan is 30GB or over (including Unlimited), your roaming cap would be capped at 30GB per billing month, even though your UK allowance is higher.
    So if you're currently on a plan under 30GB and considering moving to a 30GB+ or Unlimited plan, your roaming allowance would become more limited in comparison.
    I hope this helps.
    Marquerita
    The iD Mobile Team
    Nov 5, 2026 11:37 PM UTC
    I have the same question but I want to confirm the answer provided is correct. I am on a 50gb plan from 2021, this policy means I can use 50gb abroad https://www.idmobile.co.uk/help-and-support/eu-roaming/fair-usage-policy. (Our open data fair usage policy no longer applies, meaning customers who joined iD or upgraded on or before 20th June 2023 can use their full data allowance in our 50 free Roaming destinations without incurring a surcharge.)
    If I upgrade my plan to 100gb will I be able to use all 100gb of data abroad as I joined ID mobile in 2021? Or do I lose this perk as I upgraded?
    Please ignore this promo as it can be removed at any time
    Use Your Full UK Data Allowance at No Extra Cost!
    From 1 October 2024 and until further notice, all customers can use their full UK data allowance in Roam Free destinations*, at no extra cost! We’ll notify you when the promotion ends and when the 30GB Roaming data limit is reinstated. Have a great trip!
    Nov 9, 2026 2:31 PM UTC
    Hi ​@Jetsky and ​@O D S,
    Thank you for highlighting this. We apologise for any confusion caused by the previous information.
    To clarify, regardless of when you joined iD Mobile or when you upgrade, roaming usage in our included roaming destinations is currently subject to a 30GB roaming data allowance.
    If you change your plan, you should assume that the roaming allowance available in our included roaming destinations will be 30GB per billing month, even if your UK data allowance is higher than this, if the data allowances is lower, then they will receive the same amount of roaming data as their usual allowance.
    You can view the included roaming destinations here: https://www.idmobile.co.uk/help-and-support/eu-roaming
    We'd recommend using the current roaming terms and allowances published on our website, as promotions and legacy benefits can be withdrawn or changed in line with the applicable terms.
    Nov 9, 2026 3:52 PM UTC
    Hi ​@Gemma M ,
    Thanks for the update. So you're saying all of the information on the fair use policy is incorrect?
    People who are ID mobile customer or/and have a contract predating June 2023 do not get to use all they allowance even though the policy explicitly states,
    "Fair usage policy.
    Our open data fair usage policy no longer applies, meaning customers who joined iD or upgraded on or before 20th June 2023 can use their full data allowance in our 50 free Roaming destinations without incurring a surcharge ."
    And the terms of my contract which even though are several years old state I can use all my data whilst abroad and anything over my inclusive allowance is charged at the standard rate.
