Oct 5, 2026 12:09 PM UTC
Work in China, please help me sort
I will be in China for work from Wednesday for 10 days. What do I do about data roaming and charges etc
    Oct 7, 2026 12:28 PM UTC
    Hi ​@StevieJane,
    Kindly note that China is in iD Mobile’s Roam Beyond zone, which means your UK allowance won’t work there. It’s also important to note that the available add-ons are data-only.
    While these are suitable for things like maps or browsing, they don’t include calls or texts. Any standard calls or SMS will be charged separately at out-of-plan rates.
    How the Roam Beyond add-ons work:
    • You can purchase a data-only bundle via the iD Mobile app or your online account.
    • The add-on starts immediately upon purchase and lasts for a fixed duration.
    • Once it expires, you’ll need to buy another add-on or you’ll be charged standard roaming rates (if your bill cap allows this).
    • Your regular UK allowance (minutes and texts) is not included while in China.
    How to check if you have a bill cap in place:
    • To view or change your bill cap, log in to the iD Mobile app or your online account, go to the Bills section, and select Manage bill cap.
    • You can adjust this using the slider or by entering an amount (between £0 and up to £75.00, depending on your account type).
    Add-on options:
    Data Duration Price
    2 GB 1 day £5
    10 GB 5 days £20
    20 GB 10 days £35
    Standard roaming charges (without an add-on):
    The table below displays how much you’ll be charged for any minutes, texts or data that you use.
    Roaming Pay monthly
    Calls to UK* £2.40
    Calls to China* £2.40
    Calls received* £2.40
    Texts to China** £0.60
    Texts to UK** £0.60
    Picture message (MMS) sent** £0.60
    Internet and Data (per MB)*** £1.50
    * Price per minute.
    ** Price per message / text.
    *** Data is charged or deducted in one kilobyte (KB) increments and any part KB used will be rounded up to the nearest KB.
    For more information, you can visit: https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges.
    Tip:
    Depending on how long you’re staying, it may be more cost-effective to get a local SIM in China. Since the bundles last a maximum of 10 days, you may need to purchase multiple add-ons, which can become expensive.
    If you have any further questions, feel free to let us know or pop us a message on live chat - https://www.idmobile.co.uk/live-chat - we are more than happy to answer any further questions you may have.
