Mar 20, 2026 4:52 PM UTC
i am not able to call or text from my ID ,on samsung J7. kindly help
    Mar 20, 2026 6:25 PM UTC
    Hi ​@FAKHR-E-ALAM
    Sorry to hear that you’re unable to make calls and send texts on your phone. Please try the troubleshooting steps below:
    1. Test the SIM card
    Insert your SIM card into another phone and check if you’re able to make calls and send texts. This will help determine if the issue is with the SIM or the device.
    2. Manually connect to the iD Mobile network
    Swipe down on the main screen to open the notifications panel
    Tap the Settings icon
    Tap Connections
    Tap Mobile Networks
    Turn off Select Automatically
    Select iD Mobile
    Wait a few minutes and test the service again
    3. Perform a mobile network reset
    Swipe down from the top of the screen
    Tap General Management
    Tap Reset
    Tap Reset Mobile Network Settings
    Tap Reset Settings and confirm
    Tap Reset Wi-Fi and Bluetooth Settings
    Return to the home screen
    Restart your phone
    Michael Z
