Aug 27, 2026 1:16 PM UTC
iphone problems with calls and messges
Sim only deal - joined 26/8/26 - IPhone kept my own number entered the PAC number and all my calls and messages are not working correctly messages are getting sent with either an email or standard SMS is this a common issue.
    Sep 2, 2026 12:54 PM UTC
    Hi ​@Sioban,
    I'm really sorry to hear you're experiencing issues with your mobile number. Please try the steps below, depending on the type of phone you have:
    For Android:
    • Open Settings
    • Tap General Management
    • Tap Reset
    • Select Reset network settings
    For iPhone:
    • Go to Settings
    • Tap Phone
    • Tap My Number
    • Delete the old number
    • Enter the new number
    • Tap Save
    Then follow these steps to refresh iMessage:
    1. Go to Settings
    2. Tap Messages
    3. Turn iMessage OFF
    4. Go to Settings > General
    5. Tap Reset
    6. Choose Reset Network Settings
    7. Once your iPhone restarts, go back to Settings
    8. Tap Messages
    9. Turn iMessage ON again
    Your iPhone should now recognise the new SIM and verify your number.
