Calls jumpy and text notifications not received
hayleymartin1174
For a while when I talk on the phone (not over wifi calls) it is difficult to understand what is being said as the sound is very jittery, it is also like this when listening voicemails. I also often dont receive text notifications unless I open the messaging app. Is this likely to be a fault with my provider or with my phone?
I have a J5 samsung phone that is 3 years old.
  • 1139 replies
  • April 23, 2020
Hi @hayleymartin1174
When you speak over wifi do you have any issues?
its unlikely the network would cause this issue.
Regards
Aklima
hayleymartin1174
No wifi calls are fine, it seems to odd to me that it would be my phone though since that works fine
  • 1139 replies
  • April 23, 2020
@hayleymartin1174
Have you tried to use your SIM in a different handset?
Aklima
hayleymartin1174
No but I will do, thank you
