Carphone Warehouse not fixing a handset under warranty
Carphone Warehouse have refused to fix my handset which is still under the manufacturers warranty after it stopped working due to a software update. The reason they gave is that there is a crack in the screen although this has nothing to do with the phone not working! Obviously without a working handset I cant use ID Mobile services and wont be able to continue paying for them. Where does ID Mobile stand on this?
Best answer by Ryan D
Hi @Goran ,
It is unfortunate to hear that your phone has developed a fault. Usually, the Carphone Warehouse would be able to repair your phone under the warranty, however, certain aspects can affect the warranty status of the phone, and a cracked screen is one of those issues that is not covered by the warranty.
Even if the fault is not linked to a broken screen, it still voids the warranty as a whole and the next step is to undertake a chargeable repair. You could speak to the manufacturer and ask them for assistance, but it's likely they will reject the repair too based upon the accidental damage to the device.
View originalIt is unfortunate to hear that your phone has developed a fault. Usually, the Carphone Warehouse would be able to repair your phone under the warranty, however, certain aspects can affect the warranty status of the phone, and a cracked screen is one of those issues that is not covered by the warranty.
Log in to the iD Community.
Social Login
