Huawei P20 Pro - Single or Dual Sim?
I would like to know about the Huawei P20 Pro ( https://www.idmobile.co.uk/shop/pay-monthly/huawei-p20-pro-twilight ) if it is Single or Dual Sim.
Checking the Huawei website ( https://consumer.huawei.com/uk/phones/m/p20-pro/tech-specs/ ) it says:
HUAWEI P20 Pro Single SIM:
Nano-SIM
Available in Black and Midnight Blue.
HUAWEI P20 Pro Dual SIM:
Nano-SIM + Nano-SIM
Available in Black, Midnight Blue and Twilight.
It looks like that the Twilight color it's just Dual SIM, can you confirm that?
Nano-SIM
Nano-SIM + Nano-SIM
Best answer by daniiiiiv
HI @lucac98
I can confirm that the one you're looking at on the iD Mobile site is not dual sim and will be single sim.
From what I've seen, the dual is only available from the Huawei's website, Three and a couple other third party sellers.
Regards
Dan
View originalI can confirm that the one you're looking at on the iD Mobile site is not dual sim and will be single sim.
Regards
Dan
Log in to the iD Community.
Social Login
