Huawei P20 Pro - Single or Dual Sim?
  • 6 January 2019
  • 2076 views
I would like to know about the Huawei P20 Pro ( https://www.idmobile.co.uk/shop/pay-monthly/huawei-p20-pro-twilight ) if it is Single or Dual Sim.
Checking the Huawei website ( https://consumer.huawei.com/uk/phones/m/p20-pro/tech-specs/ ) it says:
HUAWEI P20 Pro Single SIM:
Nano-SIM
Available in Black and Midnight Blue.
HUAWEI P20 Pro Dual SIM:
Nano-SIM + Nano-SIM
Available in Black, Midnight Blue and Twilight.
It looks like that the Twilight color it's just Dual SIM, can you confirm that?
Best answer by daniiiiiv 6 January 2019, 02:53
HI @lucac98
I can confirm that the one you're looking at on the iD Mobile site is not dual sim and will be single sim.
From what I've seen, the dual is only available from the Huawei's website, Three and a couple other third party sellers.
Regards
Dan
Userlevel 5
HI @lucac98
Regards
Dan
The Huawei P20 Pro is available in two models - CLT-L29C (Twilight) and CLT-L09C (Other models).
The Twilight model is Dual SIM while other models are Single SIM. However, both of them support the Nano SIM.
Hello @lucac98,
To correct what was advised above, the P20 Pro we sell are SINGLE SIM variants not the Dual SIM advised above. The device will take a nano SIM though.
Hope this helps.
Late response here…
If I buy a sim card tray that can take 2 sim cards, would my phone be capable of operating with the dual sim features?
Late response here…
Hello @Huawei Convert,
As the device you have purchased does not support Dual SIM, purchasing a Dual SIM tray wouldn’t change the software in the device to allow this, so this wouldn’t work, sorry.
