Has anyone brought the OUKITEL C5 Pro phone? Basically is it compatible with the Three Network/ID?
ID just to clarify ID is a virtual network so a phone would need to be able to use Three's 4G bandwidth for it work on ID because ID (or rather the Dixon Group) just buy Three bandwidth and rebrand it.
https://www.sunsky-online.com/product/default!view.do?subject.id=536386
Best answer by Phil
