My partner is with Vodafone and has no issues with making calls in our flat. I however cannot make calls anywhere within the flat unless I literally stick my head out on the balcony. This is such an aggravating problem since i work full time at home. Is there any way of finding out why this is happening?
Phone Signal for Calls issue
Best answer by Michelle H
We are sorry to hear about the issues you are facing when trying to make calls.
Has this issue only just started?
Do you have WiFi calling turned on? You can find out if your phone is compatible with WiFi calling via the link below:
We can also check to see if there are any issues within your area, we’ll just need to take your postcode?
Michelle
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
